Set Select List Custom field from scriptrunner clone issue postfunction.
Vineet Kumar
Hello Everyone, We are using Jira 7.6.4 and Scriptrunner 5.4.11, The task is to autopopulate a Selectlist customfield in Jira on the target issue. I have tried variuos scripts from the blog but none of them are working for me. Is something changed on Scriptrunner plugin recently? Can someone help me to get the correct script including the correct packages.
I have tried the below scripts:
CustomField customField = customFieldManager.getCustomFieldObject("customfield_17100");
OptionsManager optManager = ComponentAccessor.getOptionsManager();
Options options = optManager.getOptions(customField.getRelevantConfig(issue), null));
Option newOption = options.getOptionById("Campaign"); // Check your option id
ModifiedValue mVal = new ModifiedValue(issue.getCustomFieldValue(customField), newOption );
customField.updateValue(null, issue, mVal, new DefaultIssueChangeHolder());
def cfSelect = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Solution")
def cfConfig = selectCf.getRelevantConfig(issue)
def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find {
it.toString() == 'Campaign'
issue.setCustomFieldValue(cfSelect, value)
Mark Markov
July 9, 2018 edited
Hello @Vineet Kumar
try this
it.value == 'Campaign'
Vineet Kumar
Thanks for the response Mark, I have already tried the above option, I am getting the below error.
Caused by: java.lang.ClassCastException: com.atlassian.jira.issue.customfields.option.LazyLoadedOption cannot be cast to java.util.Collection
at com.atlassian.jira.issue.customfields.impl.AbstractMultiCFType.createValue(AbstractMultiCFType.java:39) [jira-api-7.6.4.jar:?]
at com.atlassian.jira.workflow.function.issue.IssueCreateFunction.execute(IssueCreateFunction.java:81) [classes/:?]
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014) [osworkflow-2.9.0-atlassian-1.jar:2.9.0-atlassian-1]
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407) [osworkflow-2.9.0-atlassian-1.jar:2.9.0-atlassian-1]
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606) [osworkflow-2.9.0-atlassian-1.jar:2.9.0-atlassian-1]
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:742) [classes/:?]
Gundlupet Sreenidhi
October 18, 2018
Try enclosing the value within a collection.
issue.setCustomFieldValue(cfSelect, [value])
I did something similar and it worked for me.
This is what I have:
 Issue newIssueObject = ComponentAccessor.getIssueManager().getIssueByKeyIgnoreCase(newIssueID.toString().trim())
CustomField targetProjectBoardField = customFieldManager.getCustomFieldObject("customfield_10144")
String targetProjectBoardFieldValue = newIssueObject.getCustomFieldValue(targetProjectBoardField)
log.info "Current Project Board Value for target issue ("+newIssueID.toString().trim()+") is:" +targetProjectBoardFieldValue
if(targetProjectBoardFieldValue!=null && !targetProjectBoardFieldValue.equals("") && targetProjectBoardFieldValue.length()>1){
log.info "Updating Target Issue Project Board"
Options options = optManager.getOptions(targetProjectBoardField.getRelevantConfig(newIssueObject));
log.info "Available Options: " + options
Option newOption = options.getOptionById(Long.parseLong(affectedBoardsFieldValue));
log.info "Identified Option: " + newOption
def fieldConfig = targetProjectBoardField.getRelevantConfig(newIssueObject)
def value = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find { it.optionId.toString().trim() == affectedBoardsFieldValue.toString().trim() }
log.info "Final Value:" + value
def changeHolder = new DefaultIssueChangeHolder()
def issueCustomFieldValues = newIssueObject.getCustomFieldValue(targetProjectBoardField)
log.info "issueCustomFieldValues: "+issueCustomFieldValues
ModifiedValue mVal = new ModifiedValue(issueCustomFieldValues, [value])
log.info "mVal: "+mVal
targetProjectBoardField.updateValue(null, newIssueObject, mVal, changeHolder)
log.info "Target Issue Project Board has been updated."
log.info "Validation - " + newIssueObject.getCustomFieldValue(targetProjectBoardField)
 Modify per your needs.
Like • 2 people like this
Suji Shyam August 27, 2020
Thank you so much @Gundlupet Sreenidhi .
The below script works fine.
