Hello together,
I tried to set the Story Points field according to a single Select field, to force all users to use the fibonacci values.
Therefor i simply want to copy the value of my Single Select List into the Story Point Field.
As i read, this would be possible with Scriptrunner, so i just installed the trial on a test instance, but failed badly o.O
First attempt was really simple, but woked.. almost :D
I tried a behaviour with following code:
def nsp = getFieldByName("New Story Points").getValue();
def sp = getFieldByName("Story Points");
if (nsp != 0) {
sp.setFormValue(nsp);
} else if (nsp == 0) {0}
As this would be to easy to be true, it just updates the value in the edit screen, but doesnt update the Issue.
So i tried using a "Script Listener".. therefor i found some suggestions online but none of them worked..
I tried to set a custom listener on Issue Updated and Created with the following code:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def issue = event.issue as Issue
def tgtField = customFieldManager.getCustomFieldObjects(event.issue).find {it.name == "Story Points"}
def calcField = customFieldManager.getCustomFieldObjectByName("New Story Points")
def changeHolder = new DefaultIssueChangeHolder()
tgtField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(tgtField), calcField),changeHolder)
but this just ends in an History hint for the listener "X of X failed, including the last one"
i would appreciate any help..
Thank you
Hi @Peter ,
I think you are really close. Just need to update with the value of the field instead. Also, I do not think you need to use the event object to get the issue. See :
def newStoryPointsChanged = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "New Story Points"}
if (newStoryPointsChanged){
def tgtField = customFieldManager.getCustomFieldObjectByName("Story Points")
tgtField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(tgtField), issue.getCustomFieldValue(calcField)),changeHolder)
You can use this if so that the story poitns field will update only if new story points field is changed (If you are using Issue Updated event for example).
Antoine
Hello @Antoine Berry ,
Thank you for your answer.
Since i am really new to ScriptRunner (i just installed the trial) - i might miss something obvious for you, but the Script doesnt work. (all i've done is covered within the Screenshot).
Just nothing happens. -> Do i miss something like any project configuration?
i tried the exat same code from you - without an declaratiion of issue as an event object, i got an error message, so i added this declaration again.
Hi @Peter ,
Everything looks fine ! We might need to some debugging then. Can you confirm that "New Story Points" is exactly the name of the custom field, and that it is a Number field ?
Also, you do not need to redefine issue. Please update the script as :
log.error("newStoryPointsChanged : " + newStoryPointsChanged)
def tgtFieldValue = issue.getCustomFieldValue(tgtField)
def calcFieldValue = issue.getCustomFieldValue(calcField)
log.error("tgtFieldValue : " + tgtFieldValue)
log.error("calcFieldValue : " + calcFieldValue)
tgtField.updateValue(null, issue, new ModifiedValue(tgtFieldValue, calcFieldValue),new DefaultIssueChangeHolder())
and provide the logs.
Antoine
First of all the Field is for sure "New Story Points" - but its not a Number field it is a Select List (Single Choice) - but there are only the fibonacci numbers available!
The Log ececuted with your code above is the following:
Time (on server): Wed Apr 24 2019 17:17:36 GMT+0200 (Central European Summer Time)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2019-04-24 17:17:36,382 ERROR [runner.ScriptRunnerImpl]: newStoryPointsChanged : [newvalue:11212, field:New Story Points, oldstring:1, newstring:13, id:81418, fieldtype:custom, oldvalue:11207, group:72149] 2019-04-24 17:17:36,384 ERROR [runner.ScriptRunnerImpl]: tgtFieldValue : 2.0 2019-04-24 17:17:36,384 ERROR [runner.ScriptRunnerImpl]: calcFieldValue : 13 2019-04-24 17:17:36,388 ERROR [runner.AbstractScriptListener]: ************************************************************************************* 2019-04-24 17:17:36,388 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: <inline script> java.lang.ClassCastException: com.atlassian.jira.issue.customfields.option.LazyLoadedOption cannot be cast to java.lang.Double at com.atlassian.jira.issue.customfields.impl.NumberCFType.getDbValueFromObject(NumberCFType.java:45) at com.atlassian.jira.issue.customfields.impl.AbstractSingleFieldType.updateValue(AbstractSingleFieldType.java:151) at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:426) at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:396) at com.atlassian.jira.issue.fields.OrderableField$updateValue.call(Unknown Source) at Script483.run(Script483.groovy:16)
Thank you so much for your help!
Really appreciate it!
Thats true - strange!
So again:
The Field Name "New Story Points" is correct - but its no Number field -It is a Select List (Single Choice) - with only fibonacci (Integers) available.
The log produced with your code is as follows:
And at last i wanted to thank you very much for your help.
hopefully there is a soloution =)
Yes, there definitely is a solution, try this :
def calcFieldValue = issue.getCustomFieldValue(calcField) == null ? null : (Double) issue.getCustomFieldValue(calcField).getValue()
I have not tried it but it should do the trick.
Antoine
Thank you so much!
This almost did it - however the cast didnt work properly (see log)
2019-04-25 09:19:59,242 ERROR [runner.ScriptRunnerImpl]: newStoryPointsChanged : [newvalue:11208, field:New Story Points, oldstring:13, newstring:2, id:81442, fieldtype:custom, oldvalue:11212, group:72173] 2019-04-25 09:19:59,243 ERROR [runner.ScriptRunnerImpl]: tgtFieldValue : 13.0 2019-04-25 09:19:59,243 ERROR [runner.ScriptRunnerImpl]: calcFieldValue : 50.0
however, i only changed the "cast line" to the following, and it worked fine
def calcFieldValue = issue.getCustomFieldValue(calcField) == null ? null : issue.getCustomFieldValue(calcField).getValue().toDouble()
Glad to help ! :) Indeed this is a proper way to cast.
If you are satisfied with the answer please consider marking it as accepted.
Antoine
Hi Antoine,
I am using Jira v8.6
I am getting an error when I try to use either:
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object '5' with class 'com.atlassian.jira.issue.customfields.option.LazyLoadedOption' to class 'java.lang.Double'
at Script151.run(Script151.groovy:22)
OR
(Double)issue.getCustomFieldValue(calcField).getValue()
Any suggestions on how to fix this?
Also, looks like the function 'getValue' is no longer available.
Rupa
