Set a created date to now whenever a Jira issue is moved from one project to another project
DevaKiran
Hi All,
I need a script to the following requirement:
Whenever a Jira issue is moved from one project to another project the created date will set to the present date.
Could anyone please provide a script for the above requirement.
Thanks in Advance!!!
Regards
Deva Kiran
Antoine Berry
Hi @DevaKiran ,
I would suggest to add a script listener on the Issue Moved event. Select the appropriate projects and use this script :
import com.atlassian.jira.issue.index.IssueIndexingService
def changeItem = event?.getChangeLog()?.getRelated("ChildChangeItem")
def sourceProject = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "project"}?.oldstring
def targetProject = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "project"}?.newstring
if (sourceProject && sourceProject != targetProject){
issue.setCreated(new Date().toTimestamp())
def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService)
issue.store()
issueIndexingService.reIndex(issue)
 Let me know if that helps.
Antoine
HimaBindu M January 10, 2020
Hi Antoine,
The above script worked in our project. Thanks a ton for your prompt response. Your reply saved lot of time for me and Dev.
Many thanks again,
Kind Regards,
Hima
Like • Antoine Berry likes this
Antoine Berry
You are very welcome ! Glad it helped. :)
