Set assignee based on custom field value
Shlomi Cohen November 19, 2017
Hi
I want to add a postfunction script that sets the assignee based on a custom fields value.
So for example when field 'Product' (Select List Single Choice) a has value 'Cloud' then it should be assigned to person 'gwll' user name. If it's value 'Server' then it should be person 'Johnl' user name. We do have scriptrunner, can anybody tell me how the script should look to enable this?
I tried the following script but it set the assignee value on issue as unassignee
String userName;
switch(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Product").toString()){
case "Cloud": userName = "gwll";break;
case "Server": userName = "Johnl";break;
issue.setAssignee(ComponentAccessor.getUserManager().getUserByName(userName))
Jira - 7.2.7
ScriptRunner - 5.2.1
thanks for your help
Alexey Matveev
November 19, 2017
String userName;
def csProduct = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Product")
switch(issue.getCustomFieldValue(csProduct)){
log.error(userName)
log.error(issue.getCustomFieldValue(csProduct));
Hi Alexey
thanks for quick reply, I am getting same results - the Assignee value set to Unassigned value
any idea ?
Sorry it's works. there is two Product custom fields
Chiara Squilloni February 2, 2018
Hi @Alexey Matveev
I'm using a similar post function:
MutableIssue issue = issue;
String userName;
def areaRiferimento = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Area di riferimento")
switch(issue.getCustomFieldValue(areaRiferimento)){
    case "Qualità": userName = "mfaedda";break;
    case "Sicurezza": userName = "acubeddu";break;
But the inline script return me an error: "Cannot find matching method"
What I am missing?
Thank you so much.
Alexey Matveev
February 2, 2018
Do you mean you hava a static compilation error? Could you provode a screenshot?
Like • Amine Tanboura likes this
Alexey Matveev
February 2, 2018
What is your jira version?
6.4
Alexey Matveev
February 2, 2018
Try like this
import com.atlassian.jira.user.ApplicationUsers
String userName;
issue.setAssignee(ApplicationUsers.from(ComponentAccessor.getUserManager().getUserByName(userName)))
Chiara Squilloni February 23, 2018
Sorry, also this does not work. I will work again on it after the jira update.
Rachid Amajoud May 18, 2018
hi,
i've also an issue with implementing this, i am using the following script:
String userName;
switch(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Division").toString()){
    case "AB": userName = "Tom";break;
    case "CD": userName = "Tom";break;
    case "EF": userName = "Steven";break;
    case "GH": userName = "Steven";break;
I made a custom field (Radiobutton) and added to some screens, how should this work?
We have scriptrunner but i cant't choose for radiobutton? Is there any advice?
thx!
Amine Tanboura October 18, 2022 edited
Hello @Alexey Matveev _Appfire
I tested your code and it's working
Thank you
Amine Tanboura,
