Set comment visibility level with Behaviours plugin
RomainD February 3, 2013
I would like to automatically set the comment visibility level on an issue.
It seems possible with the Behaviours plugin (see here!). But, when I try this solution, the level is set to "All users" and not to the appropriate role. Have you got an idea of what I'm doing wrong ?
Can you help me with this?
Thanks in advance.
Christian Czaia _Decadis AG_
February 4, 2013
I was just asking since I've just seen the behaviours plugin in action if you're on an create or edit screen not when you're commenting as part of the "comment" issue action...
February 4, 2013
Just a question, are you looking at the comment on your view screen or the comment field when you edit an issue?
RomainD February 4, 2013
I'm looking for a solution for both!
