Set condition on custom field using select list
Lynn Gariepy
April 27, 2014
I'm on Jira 6.0.8.
I created a custom field using a select list with 5 values. If user chooses 1 of the 5 values, "D", then the issue should follow a different workflow. If the user chooses on of the other 4 values (A+, A, B or C), there should be no change to workflow.
I am looking for guidance on how best to configure this requirement.
Thank you,
Lynn
Lynn Gariepy
April 28, 2014
Hi Nic,
I figured it out, thanks!
Lynn
Nic Brough -Adaptavist-
April 27, 2014
Simple answer is that you can't do it.
The workflow an issue goes through is determined entirely and only by the issue type of the issue in the project. The other fields are utterly irrelevant. If you want to change workflow, you have to change the issue type. End of story.
You *could* try to wedge this in - find/write a listener that will pick up edits, catch "select list changes from something to D" and try to change the issue type, but that is not an easy task, and I've yet to see changes to issue type automated and working in all but the most simple of cases where the settings for the issues are identical, including using the same workflow!
Your best option is probably to merge the workflow. Create two paths through the workflow, and use conditions that say "you can only see transitions in route 1 if "D" is set" and another to say "you can only see transitions in route 2 if "D" is NOT set"
Lynn Gariepy
April 27, 2014
Hello Nic,
Actually the last paragraph looks very interesting. The idea is if field is set to D, go from Dev Complete directly to Ready to Deploy in the same workflow as A+ through C values that will use.
Can you show me an example of how to set the two paths in the workflow?
Lynn
