Set custom field value [Script Runner]
Aitor Bermejo Cacho
Hello All,
I want to set a value for a custom field.
I try it to do it with a text field but didn't work...
def cf = customFieldManager.getCustomFieldObjectByName("testgroovy2")
issue.setCustomFieldValue(cf,"Its Works")
How can I fixed it?
if I want to do it with a select user field....what I need to add?
Thank you all!
Community moderators have prevented the ability to post new answers.
Post a new question
7 votes
Mark Markov
March 27, 2019 edited
Hello @Aitor Bermejo Cacho
You also need to save changes with IssueManager, like this
def issueManafer = ComponentAccessor.getIssueManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def userCf = customFieldManager.getCustomFieldObjectByName("user picker")
issue.setCustomFieldValue(userCf, user)
issueManafer.updateIssue(user, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
 And to set User Picker, you need to pass ApplicationUser object.
Aitor Bermejo Cacho
Thank you @Mark Markov , its works!
but, works if the field its text field...if I use a user picker?
Like • Stephane Eicher likes this
Mark Markov
March 27, 2019
If it user picker, you need ApplicationUser object. Like in my example it sets currentUser in "user picker" field.
If you need some other user, use UserManager
def userManager = ComponentAccessor.getUserManager()
def userToSet = userManager.getUserByKey("userkey")
issue.setCustomFieldValue(userCf, userToSet)
Aitor Bermejo Cacho
Thank you!
YogeshRanjit December 11, 2019
Juan José Marchal Gómez
December 23, 2019 edited
Hello @YogeshRanjit
I think this is a typical error of beginer...
If you are doing the code in Console, please define one issue and use it.
If you are doing the code in postfunction or listened only is necessary to declare.
//Test para Console
def issueKey = "IESD-14862"
def issueManager = ComponentAccessor.getIssueManager()
def issue = issueManager.getIssueObject(issueKey)
//def issue = issue as Issue
log.info("issue: "+ issue)
Like • 2 people like this
haventName February 14, 2020 edited
OR
import com.atlassian.jira.user.util.UserManager
@StandardModule IssueManager issueManager
Issue issue = issueManager.getIssueByCurrentKey("ISSUEKEY-00000")
some code...
Like • BrianB likes this
@Akshithrekulapelli March 24, 2022
can some one help me on this I want to multiple 3 different field values and display them on 4th field
Like • Victoria Pantalone likes this
