Set field on transition only if field is empty
Jeanne Howe
October 24, 2014
We are trying to capture certain transition dates for SLA purposes. I know I can set a custom date field as a post function to a transition. The problem is, if the issues moves back through the same transition more than once, the date field is updated each time, over writing the original value. I only want to capture the first time it transitioned. How do I set up a past function that will set the custom date field ONLY if the field is empty
Randall Robertson
October 24, 2014
You can set up a conditional post function. Conditional Post Functions are possible with the Workflow Enhancer plugin. Also see its documentation.
Joe Pitt
A simple way is to create 2 transitions;
1. checks and if the field is empty it will be available and sets the date in a post function
2. checks and if field is not empty it will be available and doesn't touch the date.
Mrudula.Madugu March 5, 2019
How to doesn't touch the date using default Jira post function?
Like • Joe likes this
Dmitriy Pelevin
September 5, 2019
One transition have post function, another not.
What transition to use checked by field value.
