Sign up Log in
Set jira comment visibility using JSON Import?
Rahul K
Can I set a JIRA comment visibility to a specific JIRA group using the JSON import feature?
pborkowski
August 20, 2015
Unfortunately security levels are not at all implemented in the JIRA Importers plugin, although it's on our Roadmap, together with the JSON Export tool. https://ecosystem.atlassian.net/browse/JIM-1149
Rahul K
Thanks..Any other way to set visibility for comments? I need to do this in bulk.
pborkowski
August 20, 2015
I can only think of REST API currently: https://docs.atlassian.com/jira/REST/latest/#d2e1200.
Rahul K
yes, but the REST api does not allow me to add the comment date in the input response
pborkowski
August 21, 2015
I don't belive there's an easy when to do it, I think first you would need to import all of the data, and then update security information via REST.
Rahul K
Thanks.
