Set "Resolution" field as optional
Meech
Is it possible to set Resolution field as optional field? Checked in field configuration of the project, there are only Edit | Hide | Screen option.
Is this field is set as required by default since it's a system built-in field?
thanks & regards,
Michelle
Thomas Schlegel
Hi Michelle,
this was already discussed here: https://answers.atlassian.com/questions/26164/resolution-built-in-field-is-always-required
Cheers
Thomas
Natalia Glinka October 22, 2020
That's a bummer... I've hoped it was hidden in the Workflow validators, just like "Affects Verion/s" was (possible to make a system field optional then).
