Set the flagged using Behaviours
Shawn Danisa August 23, 2018
I would like to automatically set the flagged(impediment) field using JIRA ScriptRunner Behaviours.
Below is my script:
def flagged = getFieldById("customfield_10100")
flagged.setFormValue(["Impediment"])
This does not seem to work and I am not getting errors either.
Please assist
Mark Markov
August 23, 2018
Hello @Shawn Danisa
What type is flagged field? And where you put your script, initialiser or mapped to a field?
Hi @Mark Markov
It's a checkbox
Mark Markov
August 23, 2018
If you want to set Form value for selectlist or check box, you must provide option id.
Like this
def optionsManager = ComponentAccessor.getOptionsManager()
def customField = customFieldManager.getCustomFieldObject(flagged.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
def optionToSelect = options.find { it.value == "Impediment" }
flagged.setFormValue(optionToSelect.optionId)
See scriptrunner documentation for more information
