I created a custom field label type:
I would like to set a value using script runner (script listener).
How can I set custom field value to a label field using script?
BR,
Daniel Mor
Hi @Dan27 ,
You can have a look at this other thread where there are options for Jira 6+ and Jira 7+ : https://community.atlassian.com/t5/Jira-Core-questions/How-do-I-add-a-label-in-post-function-using-scriptrunner/qaq-p/455147
That should also work in Jira 8+. Please scroll till the end of the answers as the Jira 7+ API changed a bit the script (all is explained).
Let us know if you still have issues!
Cheers
Hi, Daniel! try this:
issue.setCustomFieldValue(labels_field, [new Label(null, issue.getId(), labels_field.getIdAsLong(), "Label")] as Set)
more can be found here:
Register now
