Setting GMT Time Format under Look and Feel
Sameera Shaakunthala [inactive]
September 1, 2011
We have a JIRA 4.3.2 standalone installation on a linux host. The server's local time & timezone are set to GMT.
Under Administration --> Look and Feel, if set up the format as HH:mm:ss ZZZ time is dispalyed as 09:20:02 Etc/GMT.
How do I remove the 'Etc' part? Is there any combination of Zs that I can apply, or do I need to edit any templete/ configuration file?
Ideally time should be shown as 09:20:02 GMT.
MatthewC
September 1, 2011
To get GMT you use a lower case 'z'
e.g.
kk:mm z - 12:16 BST
dd/MM/yyyy kk:mm z - 02/09/2011 12:16 BST
The etc is because you're on a Linux host:
http://sources.redhat.com/ml/glibc-bugs/2005-10/msg00071.html
September 1, 2011
Thanks for the answer.
Using one simple z makes the timezone part '+00:00'
Eg: 20/Jul/2011 05:29 +00:00
Is there any tweak that can be applied to the host OS?
MatthewC
September 1, 2011
  • What JDK or JRE are you using?
  • What flavour of Linux?
September 1, 2011
  • JRE version 1.6.0_26
  • Linux SuSe Enterprise Server
