Setting JAVA_HOME
Tim Graboski
July 20, 2011
Hi. I'm installing Jira on my linux computer for personal use. I am learning linux but it's a little spotty in some places, particularly with the JAVA_HOME variable. I know that from a terminal I can go
$ export JAVA_HOME=/usr/lib/path/to/java/jdk
but I believe this only sets the variable for this session, for me. Is this true?
If so, how do I make it so that JAVA_HOME is set before Jira starts? I'd like Jira to run when I turn on my computer, so it shouldn't have to wait for me to set it.
Nic Brough -Adaptavist-
July 20, 2011
Yes. But if you add it to the file .bashrc it will run every time you log in automatically (assuming you use bash as your shell - it is the default for most of the more popular distros)
Similarly, you can add it to the scripts you use to run Jira. Have a look for "setenv.sh" if you're on Jira standalone.
Deleted user July 20, 2011
I think export will set the variable for as long as you ar logged in. However there is another way:
http://glassonionblog.wordpress.com/2008/07/21/linux-setting-java_home-for-a-single-user-and-all-users/
Jobin Kuruvilla [Adaptavist]
July 20, 2011
Set it under the bash profile as explained here.
