Setting Worklog Pro Account based on issue field
Eslam
January 17, 2022
Dear all,
I'm new to Jira, and I am struggling with some automation rules for the Worklog Pro. I want to set the Account for Worklog Pro automatically based on a defined custom field C7.
I could not find a way to do it using automation rules so Itried to script it.
import com.atlassian.jira.issue.Issue;
def fields = getIssueFields(issueKey);
if (worklog.account == null ) {
worklog.account = fields.C7
return issue
so that if there a worklog entry it check if account is not set, and if null it takes the C7 value.
could you please let me know, if you know any possible way to do it.
Thanks much.
Deniz Oğuz - The Starware
January 17, 2022
Is this field an instance of WorklogPRO's Account custom field? If it is, you don't need to do it, WorklogPRO automatically assumes that worklogs for an issue which doesn't specifies their own account, uses account field of the issue. Can you create a support request to discuss the details?
