Setting a default value for a drop-downs based on selected issue-type
Dinesh
I have a Project with custom Issue types(A, B and C) and I have a drop-down(Drop-down1) present in Create screens of all these Issue types.
Drop-down1 Values ----- Mango, Banana, Apple.
So when Issue type A is selected I would like to set the Default value of Drop-down1 to Mango and for other issue types I would like it to be "None"
I tried setting up a different context for same project twice but it does not allow me to do so.
Can this be achieved  ?
Thanks for the help!
Kian Stack Mumo Systems
Dinesh,
You cannot do this using custom field contexts. I understand the desire, but it isn't possible with the base functionality.
Kian
Dinesh
Thank you
Alexey Matveev
February 4, 2019
You would need a plugin for it.
For example, you could use the Power Scripts add-on:
https://marketplace.atlassian.com/apps/43318/power-scripts-jira-script-automation?hosting=cloud&tab=overview
You could add a Live Fields with a code like this:
if(issueType == "Epic") {
  lfRestrictSelectOptions("customfield_10703", {"1", "2", "3", "4", "5"});
You can read more about Live Fields here:
https://confluence.cprime.io/display/JJUPIN/Live+Fields
Dinesh
February 5, 2019 edited
Hi Alex,
Thanks for your response.
Currently we don't have Power Scripts add-on installed in our system. Is it possible to implement this functionality using Script Runner?
