Setting default value for a custom text field
Melanie Pasztor
Hello!
Having trouble setting the default form value for a custom multi-line text field when creating an issue, using scriptrunner behaviours. It works for system description field as per a scriptrunner example, but no clear way to achieve the same for a custom description field. Also total lack of information on underlyingissue class in the documentation.
def descField = getFieldById("customfield_#####")
def defaultValue = """1. Lorum Ipsum
2. random text
3. blah blah
4. Profit!
""".replaceAll(/ /, '')
if (!descField.getValue()) {
descField.setFormValue(defaultValue)
Tried setting it to check if the custom text field is empty, but does not work, likely not knowing for where. Hence the underlyingissue class.
It would be 'if (!underlyingIssue?.description)' for a system description field, so what would be the equivalent for a custom text field?
I tried 'if (!underlyingIssue?.getFieldById("customfield_#####"))' and ' if (!underlyingIssue?.descField)' and other variations to no avail, but spits the error that it does not exist for the class.
Appreciate any help with this, or pointing towards a better method.
Patrick
Use getCustomFieldValue:
def descField = getFieldById("customfield_10084")
def descFieldObj = customFieldManager.getCustomFieldObject("customfield_10084")
2. random text
3. blah blah
4. Profit!
if (!underlyingIssue?.getCustomFieldValue(descFieldObj)) {
Regards
Patrick
Melanie Pasztor
Ah, thank you! :)
Ranganath HV Gowda
April 26, 2022
This works, thank you @Patrick
kiranmai_genkolla January 19, 2024
Hi @Patrick ,
i have used this code in customfield on behaviour .. where pretext is populating but its not storing any data in that field
Patrick
@kiranmai_genkolla
hmm..it works for me with Jira 9.12  / latest Script Runner
