Setting of Epic link depends on Epic status
Sergej Grasmik February 13, 2019
Is there a way to restrict possibility to set/edit 'Epic link' in a story if parent's epic's status is e.g. 'In Progress'?
TIA!
Marc Minten (EVS)
February 14, 2019
I assume you have scriptrunner (you added it as tag).
You can easily define a behavior to make the field Epic Link = read-only when the issue belongs to an Epic and that Epics status = In Progress.
Sergej Grasmik February 14, 2019
Hi Marc,
thanks for your answer. I already tried to set that in Behaviours, but there is no condition for that - behaviour_conditions.PNG
Or did you mean adding a script below? If yes, could you provide an example please, cause examples in scriptrunner's documentation don't contain any cases with Epic.
