Should JIRA be backed up prior to installing a new add-on?
Thomas Hardin
Hello all,
While, I believe this question is a bit foolish, I am asking because my organization does not have a strong background with JIRA and would feel better having more information from other experts.
They are trying to develop an Add-On evaluation process and feel that the target JIRA instance should be backed up prior to installing a new on. These are marketplace add-ons from reputable vendors. What are your thoughts?
2 accepted
Nic Brough -Adaptavist-
May 1, 2018
Short answer is an unreserved yes.  Always backup before big change.
That said, I rarely do it.  I've only seen one add-on break a system badly enough to start considering going to a backup, and we should have caught that well before it was rolled out (the admin did not go through a test cycle, which really would have spotted it instantly).
I would be a bad person for saying "no, don't back up", because there's always a small chance you'll need it.  But in my experience, you probably don't need to.
Thomas Hardin
What was the add-on? If I may ask.
May 1, 2018
An old Adaptavist one from before Marketplace existed - it was the Plugin Licence Manager.  You shouldn't run into it any more (I would check with Jon before saying this as accurate, but I have a feeling the need for it went away when Confluence 4 was released)
Joe Pitt
May 1, 2018
Yes. Blessed is the Pessimist for they shall have a backup (or two)
Satish Tatikonda May 3, 2018
1. Check the Compatibility of the Add-on in the new or latest or intended version quickly.
2. If it needs an update.Update it to the latest version.
3.In case it doesn't support /not compatible with the intended version then disable the add-on before going for any upgrade.Do not un-install since this may remove all the traces.
4.Later on after the upgrade enable the add-on.
Hope this helps..........
Thanks...
Thomas Hardin
Thank you very much for the help Gents!
