do anybody know where JIRA 6.4.3 shows Bamboo builds for selected JIRA project? I am running JIRA 6.3.6 with Bamboo 5.1.1 and all builds connected to particular JIRA projects are shown in
Projects > particular projects > Overview > Builds
However I cannot find it in JIRA 6.4.3, thought it is connected with same Bamboo instance. When browsing single issues I can see Bamboo builds at "Build" card. Is there any list for all builds of particular JIRA project in JIRA 6.4.x?
Regards
Leoš
Finaly I asked Atlassian Support for help. Atlassian engineer found it is a JIRA bug and raised bug report JRA-43401.
Hi Leoš,
I believe there should be a communication problem between the instances, because this should be working.
Can you please check if the Application Link is correctly configured? Are you able to see builds in a JIRA issue's Development panel?
Felipe Kraemer
Hello Felipe, thanks for your answer. Yes, Bamboo is properly listed in Application Links. I do not know anything about Development panel, but Bamboo builds are shown when listing single issues (card Build in issue view). Finaly your colleague found it is a bug - see my answer. With regards and thanks Leoš
