Show / Hide Field Based on a Project Role in Issue Navigator
Fitch_Ku April 6, 2022 edited
Hi
I want to show and hide fields in the issue navigator according to different project roles.
For example
There is a custom field of type Text: QA Comment.
The role responsible for filling this field is the PM role.
QA Comments can only be searched by the PM role in the Issue Navigator.
  • How can I achieve it?
By the way, I have ScriptRunner App but can't find suitable function to implement.
Currently the only way I know of to hide fields in the Issue Navigator is to go to the Field Configure settings, but that makes it impossible for anyone to find them.
Thanks for help
Fitch
Fabio Racobaldo _Catworkx_
Hi @Fitch_Ku ,
I had the same requirment in the past. The best way to put in place that is https://marketplace.atlassian.com/apps/1212681/secure-fields-data-security-privacy?tab=overview&hosting=datacenter plugin.
Using this app, you can define who can view and edit a specific field based on a rule (user/group or project role). That behaviour is consistent in issue view and issue navigator.
Hope this helps,
Fabio
Hi Fabio
Thanks for your reply.I have seen this app.
But I'm currently hoping to do it without an extra paid app.
Thank you~
Fitch
Fitch_Ku April 7, 2022 edited
Hi @Fabio Racobaldo _Catworkx_
I need your help.
Have other suggestions?
Thank you~
Fitch
Hi @Fitch_Ku ,
based on my experience, you have no other options to do that.
Fabio
Fitch_Ku April 8, 2022
This is also a answer.
Thank you~
Fitch
Learn more
