Show all Transition Buttons by workflow
Michael Schultz February 19, 2020
Hello. I know this is an option:
To change the number of transition buttons from the default of two:
By default, the first two transitions appear as separate buttons in the set of transition buttons. Additional transitions appear in the Workflow menu. The order in which these buttons appear is based on the order defined in the system workflow.
  1. Shutdown JIRA.
  2. Edit the jira-config.properties file in your JIRA application home directory. See Making changes to the jira-config.properties file for more information.
  3. Change the value of 'X' in the ops.bar.group.size.opsbar-transitions = X property of this file to be the number of transition buttons required before the Workflow menu.
    (info) If this property does not exist in your jira-config.properties file, add it. Otherwise, a default value of 2 is assumed.
  4. Save the updated jira-config.properties file.
    1. Restart JIRA.
However, I'd like to limit this change to only apply to the workflows which I select. Is this at all possible?
Mikael Sandberg
February 19, 2020
The short answer is no, you cannot limit the change based on specific workflows.
