Hi Experts!
I'm developing a plugin and I need to show last time its configuration has changed on plugin admin page.
In the servlet invoking the template:
context.put("lastUpdate", autoEscalateConfigDao.getRulesLastUpdate()); //java.util.Date
response.setContentType(CONTENT_TYPE);
renderer.render(UPLOAD_TEMPLATE, context, response.getWriter());
In velocity template:
#if ($lastUpdate)
<div class="description"><i>Last rules update: $lastUpdate</i></div>
#end
But this is showing something like "Last rules update: 2018-05-22 09:44:58.589"
I would like to show it in relative dates format (X minutes/hours/days ago, yesterday, ...). So I've tried:
$webResourceManager.requireResource("jira.webresources:jquery-livestamp")
#if ($lastUpdate)
<div class="description"><i>Last rules update #1: <span data-name="lastUpdate" id="updated-val" data-fieldtype="datetime"><time class="livestamp" datetime="$lastUpdate">$lastUpdate</time></span></i></div>
#end
But still the same. I've tried to surround with $datetimeformatter.format($lastUpdate), but it shows literally "$datetimeformatter.format($lastUpdate)".
I've been looking a lot of similar posts but I can't found a complete example.
I would like this date was shown in relative date format and changing when time passes, as date fields do in issue view screen.
Could you please give me some ligth about how to get this?
Thanks in advance!
________
Leirbag
you're almost done. I propose two things:
1) change lastUpdate type to Long and set the value autoEscalateConfigDao.getRulesLastUpdate().getTime();
2) add AJS.$("time.livestamp").livestamp() invocation to initialize livestamp.
Bingo! Your proposal was just what was missing in my code. I've added these two things and now it's working exactly as I want.
Thanks!!
For beginners like me needing more detailed code. This is a summary with key points thanks to invaluable help by Aleksandr.
Servlet:
package your.package;
@Named("YourServlet")
public class YourServlet extends HttpServlet
@ComponentImport
private final DateTimeFormatter dateTimeFormatter;
@Inject
public YourServlet(DateTimeFormatter dateTimeFormatter, ...)
this.dateTimeFormatter = dateTimeFormatter;
@Override
protected void doGet/doPost(HttpServletRequest request, HttpServletResponse response) throws IOException, ServletException {
Map<String, Object> context = Maps.newHashMap();
if (autoEscalateConfigDao.getRulesLastUpdate() != null) {
context.put("lastUpdate", autoEscalateConfigDao.getRulesLastUpdate().getTime());
DateTimeFormatter dtf = dateTimeFormatter.forLoggedInUser();
context.put("lastUpdateHTML", dtf.format(autoEscalateConfigDao.getRulesLastUpdate()));
Velocity template:
<head>
</head>
#if ($lastUpdate)
<div class="description"><i>Last rules update: <time class="livestamp" datetime="$lastUpdate" title="$lastUpdateHTML">$lastUpdate</time></i></div>
<script type = "text/javascript">
</script>
#else
<div class="description"><i>Last rules update: Never.</i></div>
#end
After page it has been rendered and js executed it shows something like: "Last rules update: 30 minutes ago". Time refreshes automatically and it's updated until user navigate out. When user hovers over the time tag then exact moment is shown.
Hope it would be helpful for someone.
