Sign up Log in
Showing Issue Status to Customers
Phillip Yero
Is there a way in JIRA (or an existing plugin) for a customer to be able to submit a help ticket, have it be converted into a JIRA issue, and then be able to track the status of this and all other tickets they have submitted?
C_ Faysal
November 12, 2012
if i understand it right you want customers to be able to rais an issue in your jira installation.
there is no need of extra plugin to do so.
the reporter of an issue will be informed about any updates/changes to the issue he created by default unless you make any changes to notification schemes.
you can modify a global dashboard using filter results that fit your needs (f.e. reporter = current user)
and share with your customers so they will see all their issues
to permit other peoples issues you need to set up issue-permissions
JohnA
November 12, 2012
Hi Phillip,
This can be done, but each user would require a login in the system and this would count against your license. However, if you are using an unlimited license then this wouldn't be a problem and you could just configure the "Issue Creation From Email" function configured to create issues from emails sent by customers to use the "Create Users" option, as described in this document: https://confluence.atlassian.com/display/JIRA/Creating+Issues+and+Comments+from+Email
All the best,
John
Zul NS [Atlassian]
November 12, 2012
You can have the customer informed using the mail notification in JIRA of the changes made in the issue they reported with the Notification Scheme https://confluence.atlassian.com/display/JIRA/Creating+a+Notification+Scheme
