I've tried to sign up with jira but when I try to complete the sign up it keeps saying "Registration failed. Either username is invalid or already exists, you are registering too quick, or password did not have enough complexity."
I can't fix the problem because it doesn't tell me what the exact problem is, and if registering too quickly is an issue it probably locks me in a permanent loop with this shit if I try too many times in a row, right?
So I have been completely unable to create an account.
Hi @Best ,
You can try to sign up through browser incognito mode
For Cloud products you should also check if you can login to https://id.atlassian.com/ you will see here your access to all Atlassian Cloud products
