We have a ticket structure in which there can be several levels of hierarchies (Initiatives, Sub-Initiatives, Epics, Tasks, Sub-Tasks). Initiatives, Sub-Initiatives and Epics are linked with "is parent of" links. Epics and Tasks can either be linked by the "is parent of" link or by the Epic link (or both).
Now, I need a simple JQL to return all the tickets in an Initiative, e.g. `issueFunction in featureFilter("key=KEY-123")`. I can achieve that by combining several "issueFunction in linkedIssuesOfRecursive" functions. However, that JQL is rather complex and the key of the Initiative has to be put in several places, so this is quite cumbersome and error prone.
I've tried to achieve the desired result with a custom JQL in script runner. For this, I modified the example in the documentation, see below. As long as I don't use any scriptrunner jql in the TEMPLATE_QUERY, this seems to work fine but it fails as soon as I start using other scriptrunner jqls. However, I need the "linkedIssuesOfRecursive".
So my questions are:
package com.onresolve.jira.groovy.jql import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.jql.parser.JqlQueryParser import com.atlassian.jira.jql.query.LuceneQueryBuilder import com.atlassian.jira.jql.query.QueryCreationContext import com.atlassian.jira.jql.validator.NumberOfArgumentsValidator import com.atlassian.jira.user.ApplicationUser import com.atlassian.jira.util.MessageSet import com.atlassian.query.clause.TerminalClause import com.atlassian.query.operand.FunctionOperand import org.apache.lucene.search.Query import java.text.MessageFormat class JqlAliasFunction extends AbstractScriptedJqlFunction implements JqlQueryFunction { /** * Modify this query as appropriate. * * See {@link java.text.MessageFormat} for details */ public static final String TEMPLATE_QUERY = "issueFunction in linkedIssuesOfRecursive('{0}', 'is parent of') OR {0}" /* "issueFunction in linkedIssuesOfRecursive('key in ({0})', 'is parent of') OR issueFunction in linkedIssuesOfRecursive('issueFunction in linkedIssuesOfRecursive(\"key in ({0})\", \"is parent of\")', 'is Epic of') OR key ={0}" */ JqlQueryParser queryParser = ComponentAccessor.getComponent(JqlQueryParser) LuceneQueryBuilder luceneQueryBuilder = ComponentAccessor.getComponent(LuceneQueryBuilder) @Override String getDescription() { "Filter for all children (recursively) including epic links." } @Override MessageSet validate(ApplicationUser user, FunctionOperand operand, TerminalClause terminalClause) { def messageSet = new NumberOfArgumentsValidator(1, 1, getI18n()).validate(operand) if (messageSet.hasAnyErrors()) { return messageSet } def query = mergeQuery(operand) messageSet = searchService.validateQuery(user, query) messageSet } @Override List getArguments() { [ [ description: "query to define the feature", optional : false, ] ] } @Override String getFunctionName() { "featureFilter" } @Override Query getQuery(QueryCreationContext queryCreationContext, FunctionOperand operand, TerminalClause terminalClause) { def query = mergeQuery(operand) luceneQueryBuilder.createLuceneQuery(queryCreationContext, query.whereClause) } private com.atlassian.query.Query mergeQuery(FunctionOperand operand) { def queryStr = MessageFormat.format(TEMPLATE_QUERY, operand.args.first()) queryParser.parseQuery(queryStr) } }
Hi @Thomas König ,
I’m Prosper, a support engineer at Appfire, and I’m here to help.
If you're open to other plugin suggestions, I recommend trying out our app, JQL Search Extensions (JQLSE). You can use this query
issue in childrenOfIssuesInQueryRecursive("parent")
to retrieve the children of a "parent" issue. Additionally, you can specify a depth if needed.
For more information about this query, please refer to our documentation. We also have other helper functions that you might find useful.
Don't hesitate to contact our support team if you have any further questions. We'd be happy to assist!
Best regards,
Prosper
Read the story
