Simple dependency injection in Atlassian?
todor kolev February 9, 2014
Can I use simple dependency injection in Jira/Confluence? For example simply annotating a class with @Component and then injecting in another class with @Autowired... or I need to do it using Spring Dynamic Modules as described here - https://developer.atlassian.com/display/DOCS/OSGi,+Spring+and+the+Plugin+Framework
Steve Gerstner [bridgingIT]
February 9, 2014
Use dependency injection via constructor or setter -> https://developer.atlassian.com/display/CONFDEV/Spring+IoC+in+Confluence
Thanks, for the reference Steve. As far as I can see I can only use xml declarations of beans? ... no component scanning is in place and therefore cannot use annotations?
Like • nehemuxopu@webgmail.info likes this
February 9, 2014
It's a little bit more complicatet as beside spring each bean is a osgi component.
First, you do not use xml declarations, normally.
You will define a component module which represents a spring bean and an osgi component. This module is defined in the atlassian-plugin.xml. In generall you do not handle with spring directly. And you will not handle osgi directly. That's all wrapped in the atlassian plugin framework.
I'm not sure, but maybe @Reference from Felix-SCR might work. -> http://felix.apache.org/documentation/subprojects/apache-felix-maven-scr-plugin/scr-annotations.html#reference
But I have never tried that.
Yeah component module is what I need, thanks!
Kul Bhushan Prasad August 13, 2015
More Specifically First Add the component in your atlassian-plugin.xml like
<component key="myClass" class="com.componay.confluence.plugin.MyComponentClass">
<description>Provides Body markup service.</description>
</component>
Then use setter injection/constructor injection to inject the object like
private MyComponentClass componentClass;
public void setMyComponentClass(MyComponentClass componentClass) {
this.componentClass= componentClass;
It will inject the object reference in your target class.
Kul Bhushan Prasad August 14, 2015
Another way to do it.
Follow https://answers.atlassian.com/questions/140877
Register now
