HI JIRA developers,
Is it possbile to have changes recored in 2 JIRA issues simultaneously ?
I have one issue (X-121) in project "X" which duplicates another issue (Y-3422) in project "Y".
What I want is - when I update issue Y-3422, issue X-121 should automatically get updated and it should copy all comments/status/ fields from Y-3422.
Is this possible?
Mohini
there are a few JIRA plugins out there that could provide a postfunction to your JIRA workflow that allows you to automatically transition one issue when another one is transitioned for instance. You can see more about this in these threads:
https://answers.atlassian.com/questions/183942/groovy-script-for-linked-issue-transition<br< a="">>https://answers.atlassian.com/questions/153486/jira-auto-transition-between-parent-and-sub-task
Regarding automatically adding a comment to another issue when one is commented, you may be able to do this by scripting as well. You may need perhaps register a groovy script on the issue_commented event, to run the script to comment on the other issue.
