Since release 8.x, JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class) is deprecated. It is giving warning.
Can u please suggest what should I use.
Thanks & Regards,
Pratiksha.
Why do you need WorkflowTransitionUtil? Could you share your code, please?
to make the transition through post function I need it.
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.workflow.WorkflowTransitionUtil
import com.atlassian.jira.util.JiraUtils
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import org.apache.log4j.Category
import com.atlassian.jira.bc.issue.IssueService
def Category log = Category.getInstance("com.PostFunction.PostFunction_BSS_MoveAOPProjectToArchitectureWhenFeatureArchitecture”.groovy")
log.setLevel(org.apache.log4j.Level.INFO)
IssueManager issueManager = ComponentAccessor.getIssueManager()
def userManager=ComponentAccessor.getUserManager()
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
MutableIssue AOPissue
//MutableIssue issue = issueManager.getIssueObject("DE-49333")
def count = 0
def IssueLinkManager = ComponentAccessor.getIssueLinkManager()
IssueService issueService = ComponentAccessor.getIssueService()
IssueLinkManager.getInwardLinks(issue.getId()).each{ issueLink ->
if(issueLink.issueLinkType.name =="Project-Feature Link")
AOPissue = issueLink.getSourceObject() as MutableIssue
log.error(AOPissue)
count++
if((count == 1) && (AOPissue.issueType.getName() == "AOP Project"))
if (AOPissue.getProjectObject()?.getProjectCategory()?.getName()=='BSS')
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService)
def query = jqlQueryParser.parseQuery('issuekey = "'+ AOPissue.key +'" AND status was in ("Architecture")')
def results = searchService.search( currentUser, query,PagerFilter.getUnlimitedFilter())
if(results.total == 0)
WorkflowTransitionUtil workflowTransitionUtil = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
workflowTransitionUtil.setIssue(AOPissue as MutableIssue);
workflowTransitionUtil.setUserkey(currentUser.key);
workflowTransitionUtil.setAction(171);
workflowTransitionUtil.validate();
log.error("Validated")
workflowTransitionUtil.progress();
log.error("Success")
Thanks & Regards,
Pratiksha.
You have to rewrite your WorkflowTransitionUtil part to use TransitionOptions and IssueService like it's described here.
