Single-Select Field Behave like Component/Versions with AJS
dorian_intuit October 15, 2013
I know a lot of people have asked in the past about multi-select field behaving like components/versions, but is it possible to get a single-select to behave like that as well?
When i try to edit the code, i have problems with it sticking or it will create duplicate fields
Multi-select solutions can be found:
https://answers.atlassian.com/questions/43534/can-i-have-multi-select-custom-field-behave-like-components-versions-fields
https://answers.atlassian.com/questions/62117/multiselect-fields-behaving-like-component-field-by-using-js-revisited?page=1#comment-65413
CK1's post:
<script type="text/javascript">
(function($) {
// "customfield_10400" is the number of the custom
// multiselect field you want to change as e.g.
// seen at the end of the "configure" page url of
// the field you want to change this way
AJS.$("#customfield_10400 option[value='-1']").remove(); //Removes the default value "None"
function convertMulti(id){
if (AJS.$('#'+id+"-textarea").length == 0){
new AJS.MultiSelect({
element: $("#"+id),
itemAttrDisplayed: "label",
errorMessage: AJS.params.multiselectComponentsError
AJS.toInit(function(){
convertMulti("customfield_10400");
JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) {
})(AJS.$);
</script>
Ashish Manandhar
December 24, 2020
After the adding the above script, the width of the single select custom field decreased. Is there a way to increase the width of the single select custom field ?
SABVARX
Actually the code on
worked fine for my single-select list to behave like component/version (multiple choices possible).
If you have a single-select list and want it to behave like Priority (single choice) you can use AJS.SingleSelect instead of AJS.MultiSelect. Like:
(function($){
    new AJS.SingleSelect({
        element: $("#customfield_10052"),
})(AJS.$);
</script>
Nguyen Quoc Huy
April 26, 2018 edited
You try this case: Multi-Select > Single-Select
(function($) {
AJS.$("#customfield_10159 option[value='-1']").remove();
if (AJS.$('#'+id+"-field").length == 0){
element: $("#"+id),
convertMulti("customfield_10159");
})(AJS.$);
</script>
summerke October 10, 2018
I have options in the select drop down list which start with the following (which for whatever seems to limit my ability to search using this code). Tried it out on another drop down list and it worked perfectly. Any ideas?
A.1.a - Commercial
A.1.b - UW
A.1.c  - PEAK
A.2.a - Test
