Hi all I have two single select fields.
Field A "Is color blue?"
if yes what shade of blue?
2nd field is hidden based and based on the selected answer of the first question, second question is shown.
if yes, then tell us what shade of blue. I have this code working where the second question is freeform text, is this possible with two single select fields as it is not working for me.
Yes, this is what is called dependent cascading fields.
https://confluence.atlassian.com/jirakb/creating-dependent-cascading-lists-in-jira-1142426572.html
Great and thank you Shawn. That worked. I would have preferred a pop up but your suggestion saved me a lot of time troubleshooting.
