Skipping minor versions when upgrading to latest minor of current version A.B.C->A.B.Z
Nabil Sayegh
March 2, 2014
For JIRA and Confluence:
Can I skip minor versions when upgrading to the latest minor version of the installed version?
I.e. upgrade from A.B.C -> A.B.Z directly and skipping A.B.D,..,A.B.Y
Of course I read the release notes and upgrade notes of each minor version.
Nic Brough -Adaptavist-
March 2, 2014
You can skip mid-level and high versions as well.
One Jira I used to look after took the path 2.7 -> 3.0.3 -> 3.4.1 -> 3.6 -> 3.8 -> 3.13 -> 4.0 -> 4.3 -> 6.1
Note the complete lack of v5 - slightly iffy decision if you're on anything below 4.4, but it passed all the testing and worked fine.
But yes, read the release notes for the major/minor versions. I'd skim the notes for the point releases, but they're mostly minor bug-fixes and don't usually require you to actually do anything during an upgrade, especially if you're going to move to another version again.
What I would advise is posting your current and target versions here - you'll probably get lots of specific focussed advice then!
Nabil Sayegh
March 2, 2014
I need to upgrade JIRA from 5.2.8 to 5.2.11 and Confluence from 4.1.4 to 4.1.9
March 2, 2014
Those really won't be an issue.
Skim the release notes for the point releases, but I very much you'll find anything to worry about at all.
Read the story
