Slack & Jira Integration
Ender Akgün October 30, 2018
Hi
There are any free plugin to integrate Slack & Jira?
Emily Koch
February 4, 2020
Hi Ender! I found a couple of apps that might help you out.
If you're using Jira Cloud, look for the Jira Cloud app in the Slack App Directory.
If you're using Jira Server or Jira Data Center, there's a Jira Server app that you can use instead. I hope these cover what you're looking for!
