Slack & Jira integration Failed to save configuration
Olga Videc
Has anyone come across this error
Failed to save configuration. Try again by refreshing the page or reconfiguring the channel.
I use this JQL and it doesn't want to save
((created >= startOfDay() AND created < startOfDay(8h) OR created > startOfDay(18h)) AND (created >= startOfWeek(1d) AND created <= startOfWeek(6d))
OR
(createdDate >= startOfWeek() AND createdDate <= startOfWeek(1d) or created >= startOfWeek(6d) AND created <= startOfWeek(7d)))
AND
(reporter in (membersOf("Group")) or Organizations in (Org_1, Org_2, Org_3) or (priority in (Highest, High)))
Luiz Silva
February 28, 2020
Hey @Olga Videc,
I'm sorry you've had some trouble with the integration.
As for the first query, it seems there's an unexpected additional parenthesis at the beginning. I've tried it and it seems to work like this:
The second one has an unexpected parenthesis at the end. It worked for me like this:
The third one also worked for me as long as there the group and organizations referred there existed.
The JQL editor should give you a hint when the JQL is broken, like this:
Or this:
If you are not seeing hints and errors, please check:
  • Your browser has JavaScript enabled.
  • There are not errors in your browser console that could be preventing the integration of working.
  • That you have the latest version of the integration.
I hope that helps and that you can find a solution for your issue. let us know otherwise.
Cheers!
Olga Videc
Hello Luz,
Thanks a lot, another problem has been spotted it doesn't allow more than 256 characters with spaces.
https://jira.atlassian.com/browse/API-216?jql=watcher%20%3D%20currentUser()
BR, Olga
Like Luiz Silva likes this
Luiz Silva
March 2, 2020
Thank you very much for reporting the bug. I've added this to our internal bug tracking and we will follow up with it soon.
Cheers!
Mykhailo Vlasov
April 28, 2020
Hi Olga!
I am proud to announce that this issue has been addressed in the recent release of Jira Server for Slack - 2.0.8. Feel free to upgrade to it and check if it solves your issue.
Like Olga Videc likes this
