Smart Value Condtional Logic doesn't work on customfields - JIRA Server
Sidney Joshua Ambrose May 22, 2024
Currently working on an automation where I am trying to work with conditional logic on custom fields. The conditional logic works when ever I use system fields.
For example - {{#=}} {{#issue.subtasks}} {{#if(equals(issuetype.name,"Approval"))}} {{fields.customfield_xxxxx}} + {{fields.customfield_xxxxx}} + {{/}} {{/}} 0 {{/}}
However, when I try to use the same logic on customfields, it doesn't work
Example - {{#issue.subtasks}} {{#if(equals(fields.customfield_xxxxx,"String"))}} {{fields.customfield_xxxxx}} {{/}} {{/}}
Please do let me know your thoughts
Kalyan Sattaluri
May 22, 2024
Hello @Sidney Joshua Ambrose
In this below syntax:
What kind of field is this custom field?
Cause if its single select check box, drop down, you may have to use customfield_xxxxx.value..
If its multi select field field, then, even if you use customfield_xxxxx.value, it will provide a list and you cannot compare it to a value, you need to use "match" function instead..
So, need details on this field for us to tell if you can tweak your current syntax or you need a different way to do you check.
Thank you so much for the help. It was a drop down and I used "customfield.value" and it worked.
Sidney
