×I'm using Jira Server and having issues getting the correct values returned from 'deletedFieldChange.valueIds' in an Automation. I'm logging these values to changelog so I can see them.
The automation syntax, as far as I can tell, is correct.
I based it off the documentation for smart values. I see in some comments these shouldn't be compatible with the server version, but I don't understand why it would return the added value but have an issue with the deleted value.
Any help is appreciated.
Hello @Northern Kentucky Stargazers
What you are seeing logged is smart value {{issue.customfield_24804}} and not the {{addedfieldChange.valueIds}} or {{deletedfieldChange.valueIds}} .
The addedfieldchange and deletedfieldchange are only available in Cloud, not in DC edition.
You *could* try:
{{changelog.issue.customfield_24804.fromString}}
{{changelog.issue.customfield_24804.toString}}
But @Bill Sheboy has pointed out that there is a defect out even in the changelog.. at least for Versions field.. so try above to see if you are getting the added/deleted values correctly... Again, cautioning because there could be defect where results are wonky.
@Kalyan Sattaluri Thank you! Your answer pointed me in the right direction. I was able to find what I was looking for using:
{{changelog.Field Name.to}} and {{changelog.Field Name.from}}
It's odd that I had to use the name of the field and not the 'customfield' ID. Using to and from gives me a list of the values that I need to compare.
Thank you!
Ah yes. Now I remember.. when looking at changelog entries from rest API, like below URL, it only references field name and not custom fields. I forgot about that. But glad you looked into it and thanks for the headsup so I remember next time!
https://youdomain.net/rest/api/2/issue/ISSUE-63?expand=changelog
Hi @Northern Kentucky Stargazers welcome to the community. I looked on Atlassian's Jira site and found this issue that looks really close to what you're getting. If you agree, you could probably add some comments to it and then vote for and watch it for updates.
Hi @Northern Kentucky Stargazers -- Welcome to the Atlassian Community!
Without seeing your entire rule and the specific field-change the rule is triggered upon...
Putting those things together, I suggest the behavior of those smart values is undefined for Jira Data Center. I have personally tried some Server / Data Center smart values, such as {{issues}}, with Jira Cloud and observed unpredictable behavior.
I recommend working with your Jira Site Admin to contact Atlassian Support to learn what they say about the expected behavior: https://support.atlassian.com/contact/#/ When you hear back from them, please post what you learn to benefit the community. Thanks!
