So I am working with conditional workflows.
Evan Golden
I am working with conditional workflows.  I have 3-4 conditions on transitions, and it makes multiple transition buttons appear.  Any idea how to work with the conditional workflows to make the only button option appear that should appear?
For example.  My conditions are both number values and strings (using yes/no radio buttons)
If the value is < or = 10 then the person in the route chain should be able to approve only if also the 3 radio button string conditions equal NO.  I am seeing multiple options in the transitions, and not sure how to only display the option they should have.
Any help would be great!
Nic Brough -Adaptavist-
September 25, 2015
I'm not sure what you're doing here.  A condition does NOT make anything appear.  A condition hides a transition if the condition is not met.  If you have 4 conditions on a transition, then all four of them have to pass for the transition to be offered to the user.
If you're getting multiple transitions on offer, then you're adding more transitions, not conditions.
Deniz Oğuz - The Starware
September 25, 2015
Workflow transitions has 3 sections; conditions, validators, post functions. If you enter correct condition to conditions section (pay attention to AND, OR) you should only see valid transitions/actions. Checking value of a custom field does not available in core JIRA you will need a plugin like Workflow Toolbox
Register today
