Solarwinds Integration with Atlassian Jira Serviec Desk
Prasanna August 15, 2018
Hi All
 I am able to installed and edited .json file ? can we have sample .json file to connect our JIRA server ?  i ve completed activities and followed instruction and made Node down and  JIRA task is not created in JIRA.
 Is there any logs? where i can check ??  Kindly assist me on this please
PS: Re: Orion JIRA integration https://thwack.solarwinds.com/thread/114141
  followed this steps
Thank you and regards
Prasanna
Diana_Architect_ZigiWave
@Prasanna hi. It's been a long time since you posted your issue. Did you find a solution at all?
Perhaps, next time, you may consider using an external tool to handle the integration between Jira SD and SolarWinds?
My name is Diana and I am a solutions architect at ZigiWave. Our no-code integration platform ZigOps will help you achieve that in a matter of minutes. It allows the transfer of default and custom fields between the systems and syncs them in real-time. Our tool reads the schema dynamically and can transfer any field.
Feel free to give it a look and if you want to see how it works in action: book a technical demo.
Scott Smith
January 14, 2020
Hi Prasanna,
Did you manage to integrate SolarWinds to Jira?
Prasanna January 15, 2020
Hi Scott,
I did not get the opportunity to integrate and we are using Solarwinds though and there is no official plugins so far and we have to wait
Regards
Prasanna
