Some agents do not get email notification when they are assigned
Kyle Li
In my JIRA service desk project, i had added a whole user group as service desk agent.
and when issue assigned to them, only a few of them can receive issue assigned notifcations. others cannot.
Checked in postfix and email server log. both no email sent out log. but jira shows they should have received the notifcation
Is this a product bugs? any workaround to fix it?
Nadine Schütt
February 11, 2019
Hello @Kyle Li
We had a similar issue once and it took us ages to find out what went wrong. In the end, it turned out the problem of an agent not receiving proper notifications was caused by this agent being member of a customer organisation.
This issue is also described here: JSDSERVER-5797 Agents treated as a customer when they belongs to organizations
Hope it helps
Kyle Li
It seems it's a product bug yet. I solved this issue by remove and re- added the agents access in project role and application access.
Like Grigory Salnikov likes this
Alexey Matveev
February 11, 2019
Try to use the Notification Helper to find out if an email should be sent to users (System-> Notification Helper):
https://confluence.atlassian.com/jirakb/notifications-troubleshooting-203394737.html
Grigory Salnikov
February 11, 2019
Hi @Kyle Li
Try to do the following:
  • Enable the Outgoing Mail log in Administration > System > Troubleshooting and Support > Logging and Profiling and set it to DEBUG.
  • Reproduce the problem.
  • Check the atlassian-jira-outgoing-mail.log for any errors.
