Some issues show in my filter is not shown in my kanban.
Maxi Wu September 25, 2024
My kanban is set to "all sprint"
But I found out that if the issue sprint does not contain the current active sprint. my kanban won't show it.
Is this a feature by design? can I literally show all sprint issues?
YY Brother
September 25, 2024
Hi @Maxi Wu
Welcome to our Community.
If your kanban name is called Active Sprint, then you're using Scrum board running Agile sprints. It's the correct behavior that every sprint needs to be started and completed so as to be shown in the active sprint.
If you want your issues to show in the kanban always then you should choose Kanban template when creating this jira proejct.
Hope it helps you & thanks,
YY哥,填空题咨询
Thanks for the info.
I am not the project owner. So I have no idea what they use to create the JIRA project.
But when I create the board. There are two options. I think I am using kanban and a filter
I think I got what you are saying.
Scrum board only show active sprints.
kanban board show all sprints.
YY Brother
September 25, 2024
Kanban board has no sprint actually.
Kanban & Scrum are 2 different Agile methods.
