Sprint Capacity not showing up in Advanced Roadmaps
Thayne Munson
March 4, 2022
My organization recently upgraded to Jira 8.20.  Since that time my production environment does not show the sprint capacity as it did before the upgrade.  My UAT region with the same version does show the sprint capacity.  I can't figure out what is different between the regions.  Any suggestions?
Thanks, Thayne Munson
2 accepted
Deleted user March 6, 2022
Can you check if grouping by the team shows the same issue? When grouping by the team the tool usually shows an error, that it cannot show the capacity, if the issue source of the team is not defined:
Maybe that's the difference in both plans and something happened to the issue source you assigned to a team?
In my environment, I can see, that when the Issue Source is not assigned to a team the tool also doesn't show the capacity of a sprint when grouping by "Sprint". So:
  1. Check what is shown when grouping by Team
  2. Check if an issue source is associated with the team
  3. Associate the correct issue source with the Team in your plan
Thayne Munson
March 7, 2022
The missing association was the problem.  Must have got changed sometime during our upgrade.  Thanks for the help :)
Thayne Munson
Like • Deleted user likes this
Deleted user March 7, 2022
Happy it worked out. :-)
BR Mathias
Nigel Budd (CV)
I think you need to group by Team
