Sprint Done Index
Kiran Bakshi July 19, 2021
How do I get story point loaded in past sprints and completed during that sprint?
Benjamin
Hi @Kiran Bakshi
Usually a JQL like this will get you this:
project = project name and Sprint in closedSprints() and sprint in openSprints() and Status in (whichstatusisyourresolvedstate)
Then just add up the story points from all the issues.
Kiran Bakshi July 20, 2021
Thank you Benjamin, for your reply. I am looking for a past sprint total SP load and sum of those completed during that sprint. e.g.
For project A, 'Sprint-1' was a sprint with sprint open date Jan 1, 2021 and Sprint closed date Jan 15, 2021.
I want to run a report today July 20, 2021. How do I get the number of story points Sprint-1 was loaded with and out of those how may story points were delivered (closed) in that  Sprint-1?
Thank you
Benjamin
Hi @Kiran Bakshi ,
Once the sprint completes, you can actually pull the sprint report in the report section and select the sprint you want.  It will indicate what was deliver and what wasn't. You can also pull the burn down chart and burn up chart to see how the sprint is doing while in progress.
-Ben
Like Kiran Bakshi likes this
Kiran Bakshi July 22, 2021
Thank you Ben. This helped.
