×3-level hierarchy in Jira: Story → Task → Sub-task
The transition of the Task to "Ready for QA" is performed by Automation 1 instead of a manual action. By default, Jira Automation does not trigger another automation when an issue is updated by an automation rule.
What should be the cause and solution for this?
Hi Jira Billing,
If there are two different rules, make sure the second one has the box check on the Rule details page to all it to be triggered by another automation rule.
By default, the actions performed by one rule (e.g., transitioning an issue) do not trigger other rules. This is to prevent errors and run-away looping.
When you intentionally want this to happen, in the "downstream rule", enable the option "Allow Rule Trigger" in the details at the top of the rule:
https://confluence.atlassian.com/automation103/create-and-edit-jira-automation-rules-1488594776.html
