×Hi,
I've recently updated the Jira core 8.8.0 and started running into problems.
I couldn't connect to the server localhost:8080.
Every time I tried to connect, it prompts me will error message below.
How could I resolve this problem, as I have tried all the instructions provide by Jira.
(Error message). System plugins failed to start: We haven't been able to start all the required system plugins
We couldn't start the following plugins:
Static Assets (CDN) Plugin
Please kindly help!
I also gone through similar issue where Jira failed to start with error: We couldn't start the following plugins: Static Assets (CDN) Plugin (com.atlassian.plugins.static-assets-url)
There is wiki: https://confluence.atlassian.com/jirakb/troubleshoot-a-jira-server-startup-failed-error-394464512.html which gave comprehensive details about different kind of startup errors and solutions for them.
In my case, Plugins disabled in database resolution worked.
I queried DB to check disabled plugins:
SELECT * FROM pluginstate where pluginenabled = 'false';
and deleted the one which is causing issue:
DELETE FROM pluginstate WHERE pluginkey='com.atlassian.plugins.static-assets-url';
Make sure you stop Jira, do this clean up from DB and start Jira.
Not sure if you still see the issue, but here are few things you can do:
(Optional Steps below if the above doesn't help)
You can take a backup of the cache folders as well in the filesystem before deleting them.
Best,
Neel
