I have a JQL that gives me a list of issues that have not had the status updated in more than 7 days
project = ODIT_Tech_Ops AND issuetype = "Help Services " AND status not in (Done, Cancelled) AND NOT status changed AFTER -7d
This is the result set
You'll notice that TO-2568 was created on 1/18/2023 and should not be included since the status update would have happened prior to the issue being created.
This same JQL produces results as I would expect in other projects but not this one.
Is the JQL not correct or do I have a different issue?
Hello @SJ
In my opinion the results are correct.
Your query is asking for issues that have not had a status change in the past 7 days. That is a bit different than asking for issue that had a status change more than 7 days ago.
The status of TO-2568 has not changed in the past 7 days, assuming that Open is the initial status for your issues. It was created on the 18th and its status has not changed within the past 7 days. Therefore it is included in the list.
Hi @SJ
When an issue is created, it begins its life cycle from the initial state. So, we can't really consider the starting status as a status change.
You could add another condition that ensures that it's been at least 7 days since the issue was created i.e., 'created <= -7d'
<Your JQL query> AND created <= -7d might work as you expect.
Let me know if this helps :)
Bhanu
