I have a specific workflow that I'm trying to get set up. One of the things I'd like to do is execute a transition - the end result to be reset the state to 'open' - if an issue is reassigned.
I have Script Runner up and working and a listener set up with a fast track transition.
If the assignee changes it does indeed try to run. The issue is that it only works if a user assigns something to themselves, not if they assign it from themselves to another user.
Looking at the permissions on my transition only the current assignee has rights to execute the transition. I'm guessing that this is running in the context of the new assignee and therefore doesn't have the necessary rights.
How do I get this working?
What versions are in play here? Yes, definitely tail the application log, if it can't transition it should report why not (in the latest version).
@Jamie Echlin [Adaptavist] indeed there was - 'only assignee' could 'stop progress' on a given task. I removed that limitation but the issue persists. Is there a log, etc I should attach?
Is there a condition on the action that goes to Open, like "only assignee" or something? Your question seems to imply there is. To test your theory can you temporarily remove that condition?
