Store approved Documents directly to FTP location
Leonido Gebhard
What I am trying to achieve is that files being uploaded in the Documents (Business Project) are automatically stored into a specific FTP-Folder.
I tried OneDrive but due to permission issues it's not what I wanted.
i.e. In the business project where Documents are being approved etc. I want the file uploaded into ftp after it got the status "approved" before that it should stay within atlassian to save storage and also to keep overview.
Is there a solution for this?
Nic Brough -Adaptavist-
June 23, 2019
You will need to find or write a listener that can detect "issue changed", check if things were attached to it, then copy them over to the ftp service
Leonido Gebhard
Hi @Nic Brough -Adaptavist-
Thank you. Can you point me to a guide on how to achieve this?
June 24, 2019
Depends on how you want to implement this code.
Do you want to write an app for yourself or are you thinking to use something like ScriptRunner?
Leonido Gebhard
I was thinking this was already somewhere in Jira but I just did not notice it.
Now I think I will place a feature request :)
ScriptRunner seems to be a good idea
June 24, 2019
https://library.adaptavist.com/entity/update-the-value-of-a-custom-field-using-a-listener might be a good place to start - it gives you a scripted listener, and a little about field handling, which you can replace with code that does your copy of the attachment.
Leonido Gebhard
hmm my bad. I should have mentioned that I only have jira cloud :(
I guess there will be no solution on this for the cloud based jira?
June 25, 2019
Ah, then no, Cloud is never going to support that.
Learn more
