Hi all, i would like to estimate US in story points, and update remaining story points for this US i cannot find anything in Jira in order to do that. Is this possible in jira?
Not directly, as it's not quite the right thing to do.
Story points should be added to a story as your team estimates them. Whilst modifying them before they go into a sprint is fine, changing the story points once you've committed to doing them is bad practice as it stops you being able to report on what you've achieved or not.
That said, there's nothing wrong with updating as you go. But that needs scripting or automation in Jira.
I would
thanks for the reply, do you have some scripting/automation Apps to privide this ?
cheers
There's a good starter script at https://community.atlassian.com/t5/Questions/Sum-of-custom-field-values-from-subtasks-in-parent-issue-custom/qaq-p/132517
that is a good script anyway , it cannnot reflect on the standar burndown chart ?
If you have numeric output from it (i.e. the calculation goes into a numeric field), then yes, you can show it on burndown, because you can set the estimation statistic to anything you want.
Of course, you still burn down on "story completed", as there's no partials in scrum.
Save your spot
