×greetings,
I am using history on structure, and I am trying to count the occurrences of a field's history but I get some issues.
using a simple
history.changes
.FILTER($.field = "Status")
I get all the status changes in the field:
Status -> to do, Status -> in progress etc.
I need to count the number of changes, but if I simply wrap the formula in a COUNT it gives weird results (i.e. 3 status changes but the count says 10).
How can I fix it?
thanks
Hi @Mauro Bennici , thanks for your question.
You can also reach out directly to the vendor of Structure, who should be experts on how the product works - Structure by Tempo - Jira Portfolio Management & PPM | Atlassian Marketplace
Hope this helps.
Cheers
Hello @Mauro Bennici
The COUNT aggregate function indeed won't work here - such functions can only aggregate data from multiple items in the structure - e.g. counting the number of or the sum of Story Points of all child issues etc.
In your case, you need to count the number of transitions in a single issue in the same field. This formula should do it:
history.changes.FILTER($.field = "Status").size()
I hope this helps. If you need further assistance, please reach out to us directly at our support portal.
Best regards,
Stepan Kholodov
Tempo (The Structure app vendor)
How can I use this Formula if I want to take into account changes only when the issue was in specific statuses?
@Veronica Ibragimova
You can count only specific transitions with a formula like this:
history.changes.FILTER($.field = "Status" and $.to = "status name").size()
If you have more questions about formulas or Structure in general, please reach out to us directly at our portal.
Best regards,
Stepan
