Sign up Log in
Styling Issue Collector Template
Teresa Payne
April 30, 2018
Is there any way to remove the emoji symbols from the Feedback Form?
Arthur Gonçalves
May 2, 2018
Hi Teresa,
An alternative would be following the instructions on this knowledge article and edit the feedback.vm template file, removing the following lines:
 <div id="feedback-rating" class="matrix rating">
<div class="jic-radio">
<input class="radio triggerPosition" type="radio" id="rating-awesome" name="rating" value="AWESOME" />
<label for="rating-awesome"><img src="$baseurl/images/icons/emoticons/biggrin.gif"/><span class="rating-label">$i18n.getText("collector.plugin.template.awesome")</span></label>
</div>
<input class="radio triggerPosition" type="radio" id="rating-good" name="rating" value="GOOD"/>
<label for="rating-good"><img src="$baseurl/images/icons/emoticons/smile.gif"/><span class="rating-label">$i18n.getText("collector.plugin.template.good")</span></label>
</div>
<input class="radio triggerPosition" type="radio" id="rating-meh" name="rating" value="MEH"/>
<label for="rating-meh"><img src="$baseurl/images/icons/emoticons/wink.gif"/><span class="rating-label">$i18n.getText("collector.plugin.template.meh")</span></label>
</div>
<input class="radio triggerPosition" type="radio" id="rating-bad" name="rating" value="BAD"/>
<label for="rating-bad"><img src="$baseurl/images/icons/emoticons/sad.gif"/><span class="rating-label">$i18n.getText("collector.plugin.template.bad")</span></label>
</div>
<input class="radio triggerPosition" type="radio" id="rating-horrible" name="rating" value="HORRIBLE"/>
<label for="rating-horrible"><img src="$baseurl/images/icons/emoticons/thumbs_down.gif"/><span class="rating-label">$i18n.getText("collector.plugin.template.horrible")</span></label>
</div>
Arthur Gonçalves | Atlassian Support
Earl McCutcheon
May 2, 2018
Hello Teresa,
When Creating the Issue collector select either "Raise a Bug" or "Custom", and the "Rate this page" option with the emoji's will not be included on the template.
Then for additional customization options check out the Advanced use of the JIRA issue collector documentation.
Heiko Gerlach
Hi @Teresa Payne
there is a brand new App called "ReVitalized Issue Collector for Jira" in Atlassian Marketplace, you can style the Form with your own CSS and it even adds a Google reCAPTCHA feature for better security and anti spam.
It is reusing the existing Jira Issue Collector.
https://marketplace.atlassian.com/apps/1221494/revitalized-issue-collector-for-jira?hosting=server&tab=overview
Cheers
Heiko
